48VDC to 48VDC 0.5A PoE supply
nikhillife11
Hello All,
I want to build a PoE adaptor whose input is from a 48V / 2A battery and the output current from the PoE port should be not more than 0.5A.
Basically
Input : 48V /2A
Output: 48V / 0.5A
Can anyone guide me on the same
Nikhil
Use 2 pairs for data, the 2 remaining pairs for the DC power.
Pins 1-2-3-6 have to be used for data on both ends.
Thanks for the reply buddy But,
I want help with designing the 48V to 48V/0.5A supply. I need help with that
Nikhil
Hey Xbased,
Thanks for the help. Also can you help me with what magnetics (PoE Transformer) that I can use for GE ports actually.
Nikhil
Hey Xbased,
Nikhil
