could you plz try it
i tried every thing i swear and still can't get S- Parameter
hi,im attaching d file which contain the probe feed method,which wiil help you.
if there is error, then it can't give u results. plz remove the errors
hi
i have uploaded file .plz check
so you just want a design of a probe fed patch antenna ?
I have attached a .hfss file which was generated using the hfss adk.
- the feeding should be correctly set up in this file
- you can modify the frequency/substrate/patch to suit your case
why are you making two radiation boundary ?
can u tell me how to see polarization in hfss
