FPGA Implementation of Sigma Delta
iVenky
Advanced Member level 2
College Station, Texas
Well the above one is the basic block diagram of a first order sigma delta ADC. Now I am trying to implement that in hardware. Here's the image that I saw regarding the implementation in hardware. I have few doubts here. The integrator that is present in the block diagram above is not present in the circuit below but rather we have a RC integrator at the output of DAC which is not the case above. I tried this circuit and I am getting the Delta modulated signal at the output of the DFF. But my question is this- Will we get the same noise shaping as that of the basic block diagram? I am having a doubt because both circuits seem to be different. Will we get the same maximum possible SNR for both circuits for a given OSR?
Thanks a lot
It would be better if you used an external opamp integrator instead of a simple RC.
The RC might work well only if your input signal is very small and centered at Vdd/2. In other case your "integrator" would be a RC charge/discharge curve, not a straight line.
Ya that's okay. But you didn't answer my doubts. Eagerly waiting for your reply
As said, low-pass transfer function is different from integrator, thus you get different noise shaping. You may want to calculate it using the Schreyer's popular Matlab toolbox or a different method of your choice.
First order SD noise shaping isn't mind blowing in any case, also the transfer function is at least similar to an integrator based SDM. I don't expect huge differences.
Thanks so much for the reply. But one thing bothers me a lot. That integrator in the SD block diagram is placed after the difference whereas here the RC filter is placed after the DAC output. This should mean a different Transfer function right?
Thanks a lot
Reactions: FvM
    FvM
Yes, you are right. I overlooked this important detail. You would need another low-pass at the signal input to get a transfer function nearer to the integrator.
Ya but I took that from one IEEE paper. This should mean the above mentioned method also should work. Besides what they have written is that the output of the RC filter tracks the input signal.
