Hi izzu91which concept Power inverter use: either PWM or square wave?
Hi izzu91
As i can see name of this thread is how power inverter DC to ac works . well ?
ok it is simple to understand it . but it depends on what kind of out put wave are you referring to ? sine wave or just square wave ? are you referring to the commercial inverters which are simply available and you can use them for homes too ? sine wave out put ? if you mention it exactly then i can describe it in detail .
Best Wishes
Goldsmith
Hi izzu91yea, what i mean is the commercial inverters. i just bought 300 watt power inverter. i just wonder how it produce sine wave? is that a pure sine wave inverter or modified sine wave inverter?
