munzir
Full Member level 6
what's the difference between proximity sensor and proximity switch ?
Typically what inductive proximity sensor generates the output ? Is it a digital signal or a analog signal
If metal or metallic object is the target of inductive proximity sensor then what the output signal of inductive proximity sensor actually does ? Is it just use to switch on or switch off some device through relay normally open or through normally closed contact(s) ?
thanks
thanks
