harisharanyp
I want to convert 230 ac voltage to 3v dc using 9-0-9 transformer at the input side..How to rig-up this rectifier circuit..Is it necessary to use 7805 ic ?? Using this 3v dc to power the xbee module..plz help
Thank you for your reply.Input side means input of the rectifier.Did you mean three 3v voltage regulators? if so then please give some more info about the 3v regulator ic. Waiting for your reply.
No, he meant a regulator that gives 3.3VDid you mean three 3v voltage regulators?
Its better if u use a LM317 with a linear variable resistor
There is tons of voltage regulators see some of them :
https://www.tme.eu/en/katalog/#id_c...,362,367,35,10,364,365&used_params=364:24603;
https://www.tme.eu/en/katalog/#id_c...sed_params=364:24791,26085,26048,26501,24603;[/QUO
I'll go through the link and reply to you.Thank you.
Thank you arunava7.. Can you help me out with the circuit using LM317?
ok..Thank you.will search about it and reply to you.You can find application samples (examples of circuits) in manufacturer part datasheet. Datasheets you can find on links in post #5, just click on info link or check manufacturer web site.
:wink:
Actually, I've found it difficult to find a good 3.3V voltage regulator as such...I've used mostly LM317's and the results are fair
