bidarmard
Junior Member level 2
hello everybody
when I run an embedded project in matlab simulink the following error appears
Unable to locate 'mexopts.bat', and therefore cannot determine which compiler to use for simulation builds.
Use 'mex -setup' to select a supported compiler.
does anybody know what should I do?
I'll be grateful if you answer me as soon as possible.
thanks
thanks
