Junus2012
Hello every one
is it right that in the cascode current mirror, if we dont connect the bulk to the source of the upper transistors it will lead to better circuit work ?? according to my friend that this will lead to create like a feedback voltage which correct the operation
for me I think it will lead to worse the circuit because the threshold voltage will vary more with the applied potential
Thank you very much
Thank you very much
