This is the typical connection:
eg. Input + could be a signal coming from a PWM chip, a microcontroller or any circuitry needing to turn the MOSFET on. Input - could be connected to the ground to which that circuitry is connected to.
You can help other types of loads as well, like inductive. If you have a motor or relay, connect an anti-parallel diode across that relay.
Hope this helps.
Tahmid.
The output of TLP250 does not need a pull-up because the output stage of the TLP250 is a totem-pole stage. Plus, having a pull-up would be bad, since, when TLP250 is off, MOSFET would be on. This isn't required at all since TLP250 has a totem-pole output stage. However, a pull-down resistor has been provided from gate to source of the MOSFET to prevent it from accidental turn-on under any circumstance.
Hope this helps.
Tahmid.
Can you explain more on this? How does it turn on accidentally?
