hemanth434
hi this is my code im nt getting any output n tell me how to give inputs in the test bench waveform
entity Encrypt is
Port ( rs1 : in STD_LOGIC_VECTOR (15 downto 0);
rs2 : in STD_LOGIC_VECTOR (15 downto 0);
rs3 : in STD_LOGIC_VECTOR (15 downto 0);
rs4 : in STD_LOGIC_VECTOR (15 downto 0);
k1,k2,k3,k4 : in STD_LOGIC_VECTOR (15 downto 0);
pt : in STD_LOGIC_VECTOR (15 downto 0);
LFSR : in STD_LOGIC_VECTOR (15 downto 0);
ct : out STD_LOGIC_VECTOR (15 downto 0));
end Encrypt;
architecture Behavioral of Encrypt is
signal x1,x2,x3,x4,x5 : std_logic_vector(15 downto 0);
signal v12,v23,v34 : std_logic_vector(15 downto 0);
signal rs1_ext : std_logic_vector(15 downto 0);
signal rs2_ext : std_logic_vector(15 downto 0);
signal rs3_ext : std_logic_vector(15 downto 0);
signal rs4_ext : std_logic_vector(15 downto 0);
begin
process(rs1,rs2,rs3,rs4,pt,k1,k2,k3,k4,LFSR)
variable i : integer;
begin
for i in 0 to 3 loop
x1 <= rs1 + pt;
v12 <= x1 xor k1;
x2 <= v12+ rs2_ext;
v23 <= x2 xor k2;
x3 <= v23 + rs3_ext;
v34 <= x3 xor k3;
x4 <= v34 + rs4_ext;
ct <= x4 xor k4;
rs1_ext <= rs1_ext + v34;
x1 <= v23 + LFSR;
rs3_ext <= rs3_ext + x1;
x2 <= v12 + rs1_ext;
rs4_ext <= rs4_ext + x2;
x3 <= v12 + rs4_ext;
rs2_ext <= rs2_ext + x3;
end loop;
end process;
end Behavioral;
plse giv the solution to my problem
entity Encrypt is
end Encrypt;
begin
begin
x1 <= rs1 + pt;
v12 <= x1 xor k1;
x2 <= v12+ rs2_ext;
v23 <= x2 xor k2;
v34 <= x3 xor k3;
ct <= x4 xor k4;
x1 <= v23 + LFSR;
end loop;
end process;
end Behavioral;
