MrHfss
Newbie level 6
can someone please help me?...
1)check if airbox size is ok
2)i am changing the size of some parts (for example A2m from 16mm to 20mm)and i am trying to archieve s11<10db and gain >0db for 2.4GHz(wifi) and 1.92-2.17GHz(umts) (and 1.71-1.88(gsm 1800)if it is possible)
how can i make my antenna more broadband to archieve this?
thank you for your time....
(i am using hfss v.12 and you can unzip the file ,open hfss and then tools->run script)
