Looking for software for capturing data/graph from VNA 8720B
greg12345
Junior Member level 3
Hi
I'm looking for a software for capture data and graph from a 8720B network analyser.
I have the GPIB interface and I don't have time to write something under Labview.
I have tried intuilink (V1.2) and it doesn't work.
Could anybody help me??
Thank
Greg
agilent vee 8753
Try getting Agilent's VEE software...
They have virtual instruments (via GPIB) and ready-to-use drivers for HP8720 VNA... It will be a matter of 10minutes to acquire your data (even with no prior knowledge of the VEE environment)
mogwai.
    greg12345
softplot free download
Thank Mogwai
Is it possible to make exe file with VEE by @gilent?
Good day
Greg
agilent uncerttest.xls
You can use SoftPlot V5.0
    greg12345
uncerttest.xls agilent
SoftPlot or SPview are commercial but economic solutions.
Are you sure the problem is with intuilink?
If you have NI-Spy , you can monitoring the GPIB if data flow exist.
In any case, you should check the 8720 GPIB settings.
    greg12345
retrieve data from vna software gpib
Hi Sergio
When I used intuilink (V1.2), I was able to check the VNA and when I tried to transfert data I had the message "PU not supported".
It is stange because normally the V1.2 is able to support this VNA (8720B).
I used GPIB/USB from NI and not from Agilent. Perhap's it's the problem!
Thank
Greg
gpib 8720d
For 8720B I am using in this moment Softplot.
    greg12345
vector network analyzer 8722 price
greg12345 said:
Hi Sergio
I used GPIB/USB from NI and not from @gilent. Perhap's it's the problem!
Thank
Greg
Me too i have GIPB-USB-B from NI. and work!
I've now checked my intuilink and it support 872xD...and later
I suggest to check GPIB setting on 8720. My setting is NOT pass trough and NOT System controller. I've left the recomended GPIB address for VNA's (26)
    greg12345
ni usb gpib settings for vna
Hi sergio
Tomorrow I will Check GPIB setting on my 8720B. I hope that it will be ok.
Can you tell me your version of Intuilink? I think it's V1.3 because V1.2 support 8720A/B/C.
I will inform you to my tests on VNA.
Thank
GREG
8753c intuilink
greg12345 said:
Hi sergio
My Intuilink is ver. 1.3.0.4 and explicitally say that the compatible VNA are 8719, 8720, 8722, 8753 version D, E, ES, ET.
When i use Intuilink i do the following operations:
1) click "Identify Instruments", and wait for a response. The leds on VNA blinks.
2) Then ckick on connect
3) Manually, i set-up the wanted display format (i.e. smithchart if i want s11)
4) Intuilink v.1.3 can download the 4 spar at time only for 87xxE ; but in conjunction with the 8722D that i have, only 2 spar (i.e. s11 and s22) may by donwloaded at time.
P.S. Have you checked if others System Controller (other than the PC) are alive on your IEEE-488 bus ? Only one (the PC) is permitted.
8720b labview
Hi Sergio
I have just found moment now to try your solution!! sorry
I downloaded the V1.3 of intuilink. When I want to connect my VNA, I have the message "8720B is not a supported instrument"
It's impossible to acquire any data.
What is your VNA (8720D)??
Have you any idea?
greg
8722 vna manual
greg12345 said:
Hi Sergio
Have you any idea?
greg
Effectively, a carefully raed of the help file of the Intuilink, say that only last version of 872x family may communicate with intuilink.
I have 8722D and it's limitate to only 2 spar at time. Apparently only 872xE has full support.
Alternatively there are almost 2 commercial solutions.
SPview - Fully functional, very friendly and easy, also light (on the old V 1.42).
SoftPlot, also a very good software, just less friendly but more "industry standard".
If you are a VNA user, there are almost two related jobs that are often tedious to do:
1) Insert Cal Kit data into VNA
2) Calculate the measurement uncertainty
for both there are the relative free software.
1) www.vnahelp.com
2) search for "UncertTest.xls" on Agilent website
8720a intuilink
I had the same problem. For the graph part, the only thing I can
suggest is to get a Digital Camera and take a picture. It's not
sophisticated but it's easy.
Cheers
intuilink 8753
Hi
I have tested the eval version of SPview for make the capture of the data.
It work fine and the price is not expensive.
I think that it is a solution for the old VNA
You can download the eval version directly at :
https://www.arkrfsystems.com/downloads.htm
Greg
