mtwieg
Advanced Member level 6
I've been designing a circuit which must be capable of running off automotive batteries, possibly while the vehicle is running, so I need load dump protection. I've implemented surge suppressors in the prototype, and the circuit works fine under normal circumstances, but I have no way to test the functionality of the load dump protection. Is there any way to replicate load dump transients similar to those specified in ISO7637, without a specialized piece of equipment? Would it be adequate to just charge a large iron inductor and dump it onto the supply rail?
Also, I may have to work with truck batteries as well, which are nominally 24V. But when the battery is in a vehicle, and is being charged by an alternator, should I expect the battery voltage to rise significantly? What maximum DC voltage would I expect to see on a truck battery? I want to make sure the suppressors have sufficient standoff voltage to not conduct under such circumstances.
Finally, for truck systems, are there different load dump specs than for "normal" automotive applications?
Thank you.
Thank you.
