arbj2
Full Member level 3
I am based in India (New Delhi), I normally solder DIP devices, I would now like to move to SMD soldering. I am trying to solder this component onto a PCB
http://cds.linear.com/docs/Datasheet/3470fd.pdf
The device (LT3470) is a TS8, TSOT23 package.
Based on some google searches and viewing some youtube videos on SMD soldering techniques, I have compiled the following list of items needed.
1. A 10X Loupe (is the magnificatyioon enough??)
2. Solder Wick
3. Solder Paste
4. Solder Flux
5. Fine Tweezers
6. SMD soldering/rework station (heat gun, with other accessories)
Please advise what other items would be required, also whether the SMD soldering/rework station would be required. I have a temperature controlled goot soldering station, soldering iron with fine soldering tip would these do ??
I find using the goot soldeing iron a bit difficult as the pins of the LT3470 are very small.
Please also mention if normal solder wire could be used, also explain the use of solder flux and paste.
Some youtube videos showed a glue like substance for sticking the device prior to soldering is this available in India.
thanks
a
2. Solder Wick
3. Solder Paste
4. Solder Flux
5. Fine Tweezers
thanks
a
