[SOLVED] placing pads on both sides of pcb
Y.li
I wanted to place pads on both top and bottom layer of pcb (in eagle). Pls. tell me how to do so.
Thanks,
Y. Li
I am assuming that you are talking about pads of component ( SMD components )....... by clicking the pad you can change its properties and also on which layer you want ( top or bottom )
Reactions: Y.li
    Y.li
OK thanks.
Y Li.
MIRROR is the command for flipping components onto the other side.
Keith
