[SOLVED] Digital Design Interview Question
mail4idle2
Full Member level 4
Full Member level 4
I have a block which compares and gives the smaller and Larger number of 2 numbers.
Using above block, when 4 numbers are given as inputs, produce the outputs in ascending order. How ?
Is my question not clear ?
Please read my question once again.
Given:
a block which compares and gives the smaller and Larger number of 2 numbers....
Goal:
when 4 numbers are given as inputs, produce the outputs in ascending order....
Solution:
Assuming the numbers to be sorted are 7,1,3,6
Step 1: Take the first two numbers 7 and 1. Using your so called "block" gives smaller number as 1 and big number as 7. So swap the two numbers we get sequence as 1, 7, 3, 6.
step 2: Now move to numbers 7 and 3, give this as input to your block. big number is 7 and small is 3. So replace the positon of two numbers we get sequence as 1, 3, 7, 6.
step 3: Give the input to the block next two numbers 7 and 6. find which is greater and smaller. swap it to give the output 1,3,6,7.
Output:
Using your block we have sorted the given sequence in ascending order 1, 3, 6,7.
Reactions: :-)
Given:
Goal:
Solution:
Output:
Thanks for step by step bubble sort example... made it clear.
