T
treez
![Newbie level 1](/styles/images/ranks/alevel1.gif)
Is the following pin header capable of passing currents as low as 50uA?
Molex 22-11-2062 PIN HEADER (6373 series)
https://www.molex.com/molex/products/datasheet.jsp?part=active/0022112062_PCB_HEADERS.xml
I am told that certain connectors cannot pass very low currents, as they need a certain current level to "burn" away the oxidisation which occurs on the connector contacts.....50uA may not be enough to "burn" away the oxidisation?
