[SOLVED] 4 bit counter using J-K flipflop doubts
Barasha
Guwahati ,India
Hello all,
Designing a up counter with JK FlipFlop, where do we connect the clear and preset pins.please help
What IC's you are using Do post it
Cause some have inverted pins in the clr and preset pins And so you need to invert the input you are to give to them
Then give inverted inputs to the corresponding pins
You need to give "High" If you don't want them to be triggered and "Low when both pins have to do their work
So if you are up counting then have this pin always at "HIGH" during the count process other wise they will reset the counts every clock and you will get garbage output
Hope this helps
Hope this helps
Hi jeffrey samuel,
I gave a HIGH to both of them but the counting is not as it should be.I have a doubt.Do we need to clear first and then input HIGH to both of them.
Hi jeffrey samuel,
Yes Friend as initially some sort of Data can be present in the FF so it is better to clear the IC's before we do any fresh operation
also try debouncing your keys if they are of the mechanical type so that u dont end up giving multiple pulses at a go...cos this will certainly give you false results!
Thanks. Clearing before starting a new sequence is probably better.
Hi sequel,
I will try that.Thanks
The exact word to be used here is not faulty counting
If an additional clock is given at the same time the step wise transtion may not be noticed by us due to very fast change of states
when dealing with mechanical switches it's very important to debounce it....dats a fact in the field of electronics. nevertheless if it is purely that of a microprocessor "controller" based system we cud ofcos make use of a software loop for the delay. lemme ask a question: if a need my jk flip flop to give or just as u say a make a transition of one with just a mechanical switch wot do u tink or feel the state of the flip flop wud luk lyk?....hmmm i guess it will not be defined "indeterminate logic!". except we make use of a one shot at the input with respect to wot i hav said.....quote me if am wrong.........
sequel!
sequel!
Can you first repost here abiding the rules of the forum I am not able to get you
PS: SMS language is not allowed here
Hi Jeffrey Samuel n sequel,
Reading the sequence was difficult before when i didn't clear the flip flops.It is working fine now.Thanks.
