Please advice me for the following
PA3040
Advanced Member level 3
Dear All,
I am new for this area therefore please kindly advice me for the following
FR4 TG135?
1/1oz?
HASL?
1.6mm? I think this is thickness of the PCB
I am using Sprint layout 5 for designing
Thanks in advance
FR4 is the standard fibreglass-epoxy base for general use PCBs.
TG135 is the 'Glass Transition' temperature (135°C) - above this the board softens.
1/1oz means 1oz of copper per square foot (that's 34.8µm thick), double sided
HASL is Hot Air Solder Levelling: The etched PCB is dipped in molten solder and the excess is levelled (blown off) by hot air jets.
1.6mm is the thicckness (standard for single and double sided)
Reactions: PA3040
    PA3040
Dear Foxy,
Thanks for the reply
Could you please explain bit more on FR4 stranded
