pewang
Full Member level 3
I'd like to suggest to check not only the plot but also the raw matrix data. To check each response value and their stimulus index, you maybe could find more.
And just guess, if the ADS do the correct, the fold back on the power or PAE sweep maybe the indication of some un-stability at large signal drive. I mean the circuit stability.
