electronic_satya
Hi All,
I have this doubt about capacitors. suppose one plate of capacitor is charged with say 5V and the other plate of the capacitor with say 3V, then the two plates are at different potentials? or both of them will adjust to a common voltage? what is the voltage across the capacitor? another doubt is if i connect a capacitor across a voltage source and if the voltage raises suddenly to some voltage what is the voltage across the capacitor? According to the theory the capacitor voltage raises slowly, but using multimeter or any instrument if I measure a voltage across a capacitor it will always give me the reading of the supply voltage then how anyone can prove that the capacitor voltage raises slowly? (It can be shown with a resistor, but without resistor how can it be proved?).
Thanks in advance,
regards
Thanks in advance,
regards
