Non-Idealities in Delta Sigma Modulator (CT and DT both)
Eminent.Engineer
Member level 3
Member level 3
I would like those who have done research on Delta Sigma ADC to answer few questions.
1. What are non-idealities in delta sigma modulator
2. how to model those non-idealities in MATLAB
Kindly post/mail the relevant reading material on eminent.engineer@yahoo.com.
Thanks to all.
as far as non idealities are concerned they are related to integrator such as finite gain,finite bandwidth,offset voltage,slew rate. Comparator non idealities such as offset and non-linearity.
In DT switched capacitor circuit is used therefore there are switches which have finite resistances and non linear capacitors that cause incomplete transfer of charges. switch thermal noise . In relation to clock there is jitter.
This paper will be helpful
View attachment non ideal sdm.pdf
hope this helps
  • non ideal sdm.pdf
