Phyical Design Fundamentals (Via Insertion)
kushan_s
Newbie level 5
Newbie level 5
Bangalore
Could anyone explain the difference between Timing Driven Double Via Insertion and Non Timing Driven Double Via Insertion ?
When you insert additional (double) via, it will change RC values of this net. If you don't want to change timing of the path through this net (for example, it may has negative slack), you should use timing_driven double via insertion - it will skip the timing critical nets for double vias. By default, it will add vias wherever possible (it does not consider RC values).
