Dual gate mosfet, more information about this device?
neazoi
Advanced Member level 6
Greece
According to this paper https://www.hamanuals.com/S1/CX7/Articles/Mosfet.pdf a dual gate mosfet has significant advantages over common transistors and mosfets.
It seems that information on the internet is quite limited. Any information about biasing, characteristics, examples in circuits will be valuable.
Hi Neazoi
Usually a dual gate mosfet , will be used in RF applications . for example in a mixer or in an IF amplifier stage . it is enough that you consider it as two mosftes .
Best Wishes
Goldsmith
Reactions: neazoi
    neazoi
Hi Neazoi
Best Wishes
Goldsmith
That's two mosfets connected as a cascode configuration?
What about dynamic range, the paper states that it is much better, but this paper if of the 60's
Hi again
Of course .
I agree , that , that paper is too old , what do you need to know about dynamic range , exactly ?
Hi again
Of course .
The ability to handle very small and quite large signals simultaneously, without significant intermodulation distortion.
I was having the legendary bf981 in mind...
