s.manikandan
Member level 3
pwm generating.
consider if,
error amplifier reference voltage = 2.5V (non-inverting input)
output feedback voltage to error amplifier = 1.5V ( inverting terminal)
now the error amplifier output is = 2.5 -1.5 = 1V
Now,Ramp signal amplitude = 5V
error amplitude is = 1 v( as above)
now the PWM will increase Ton period to match the vref voltage... My doubt is, when error is ZERO, how the ramp signal and error signal comparison takes place. what will be the output... because the comparison takes place only if error is generated... otherwise.....?
consider if,
