[SOLVED] Help needed"test bench of a counter entering a value in fifo and then reading it out"
prady019
Junior Member level 3
India
this is code i wrote for test bench in vhdl
tell me did i make any mistake or guide me to write it in more simpler form.
i wrote some on my qures in comments form help me out for that.
entity counter_data_tb is
end counter_data_tb;
architecture test of counter_data_tb is
component top_level
port ( clk : in std_logic;
rst : in std_logic;
write_request_top : in std_logic;
read_request_top : in std_logic;
fifo_out_top : out std_logic_vector(7 downto 0)
end component;
signal clk_test : std_logic := '0';
signal rst_test : std_logic := '0';
signal write_request_top_test : std_logic := '0';
signal read_request_top_test : std_logic := '0';
signal fifo_out_top_test : std_logic_vector(7 downto 0);
constant clk_period : time := 2 ns;
begin
DUT : top_level
port map ( clk => clk_test,
rst => rst_test,
write_request_top => write_request_top_test,
read_request_top => read_request_top_test,
fifo_out_top => fifo_out_top_test
clk_genrate : process
begin
clk_test <= '0';
wait for clk_period/2;
clk_test <= '1';
end process;
input_genrate : process
begin
wait for 2 ns;
rst_test <= '1';
wait for 2 ns;
rst_test <= '0';
wait for 3 ns;
write_request_top_test <= '1'; -- to make read/write request i thought of this, is this write??
read_request_top_test <= '0';
wait for 2 ns;
write_request_top_test <= '0';
read_request_top_test <= '1';
wait for 2 ns;
wait for 2 ns;
wait for 2 ns;
wait for 2 ns;
wait for 2 ns;
wait for 2 ns;
wait for 2 ns;
wait for 2 ns;
wait for 2 ns;
wait for 2 ns;
wait; -- tell me what's this statement doing here??
end process;
end test;
Re: Help needed"test bench of a counter entering a value in fifo and then reading it
Please upload the clear waveform, left most side labels in your waveform is not completely visible,
Re: Help needed&quot;test bench of a counter entering a value in fifo and then reading it
What are you writting at 4th clock pulse, and what are you reading at 5th clock pulse.
i don't know what i did, but my mind is in real mess now. :(
First make the counter and then apply to FIFO register
