Veronika
Hi All,
I am using PADS Layout software. I need to create a footprint for TPS51200 regulator.
On the page 34 of its Datasheet (it is attached) an example board layout is shown. "Non Solder Mask Defined Pad" shape is suggested, but I do not know how to make it in PADS PCB Decal Editor. Is it possible to make such shape of pad in PADS Layout? If yes, then how??
Thank you in advance!
