viperpaki007
Full Member level 5
I am doing post layout simulations in cadence spectre using generated parasitic file from calibre PEX tool. Simulation results show different results than compared with pre-layout simulations. Therefore, i need to tune the layout to make the circuit working with parasitics. Previously, i used to edit the layout, generate the parasitic extraction file once again and re-run the post-layout simulations for tuning the layout. However, this process takes a long time as layout editing is quite time consuming. Is there anyway that i can tune the layout by editing the extracted netlist and later on when my design is final i can edit the layout in final run. In this way i will not have to edit the layout many times..
Looking forward for your suggestions.
