how to abaut GLCD pins
hesho90
Member level 4
egypt
and witch one to sbit to with the PIC
this my pins
VCC VDD NC A0 NC E D0...D7 BLA CS1 PS RES
If I understand your problem, you need to find out how to connect GLCD and microcontroller. On this site you have a described one professional development board based on PIC microcontrollers and there are connections for GLCD.
If you download user manual from this site, you will see how is GLCD connect to PIC.
web site about development board
i want to know what one i coonect with my pic cz i didnt see this pins befor
Glcd 128x64 jhd1286
Using the name, I find a datasheet for your GLCD - **broken link removed**
Where you seen NC pin on your schematic? Usually that means NC - Not Connect.
tyvm man you where very nice
my GLCD IS LM13232
AND I do it like that but the code get eror till me where is
rs and cs2 and my lcd dont have them
  • MK-002937-1-1(LM13232AFW-1 Outline).pdf
  • LM13232AFW-Manual-Rev0.2.pdf
  • Note for use LCD in Serial Mode.pdf
OK, now we have a documentation about GLCD. Could we define problem again and then try to solve it?
Which microcontroller you plan to use?
Did you make any schematic of your device?
Do you have any example for it?
Thank you replying
i use PIC16F877A
I DID make a example and it have errors on ISIS
and the schematic
but the code Always RS RST CS2 AND THINGS my lcd dont have it in it pins
AND my code is
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
sbit GLCD_A0 at RB0_bit;
sbit GLCD_EN at RB1_bit;
sbit GLCD_CS1 at RB2_bit;
sbit GLCD_PS at RB3_bit;
sbit GLCD_D4 at RB4_bit;
sbit GLCD_D5 at RB5_bit;
sbit GLCD_D6 at RB6_bit;
sbit GLCD_D7 at RB7_bit;
sbit GLCD_A0_Direction at TRISB0_bit;
sbit GLCD_EN_Direction at TRISB1_bit;
sbit GLCD_CS1_Direction at TRISB2_bit;
sbit GLCD_PS_Direction at TRISB3_bit;
sbit GLCD_D4_Direction at TRISB4_bit;
sbit GLCD_D5_Direction at TRISB5_bit;
sbit GLCD_D6_Direction at TRISB6_bit;
sbit GLCD_D7_Direction at TRISB7_bit;
void main()
  GLcd_Init();
  Lcd_Out(1,1,"hello");
  Delay_ms(2000);
and after i press build on mikroc it get
0 1 mikroCPIC1618.exe -MSF -DBG -pP16F877A -DL -O11111114 -fo8 -N"F:\leds\ãÌáÏ ÌÏíÏ\code\code.mcppi" -SP"D:\Program Files\Mikroelektronika\mikroC PRO for PIC\defs\" -SP"D:\Program Files\Mikroelektronika\mikroC PRO for PIC\Uses\P16\" -SP"F:\leds\ãÌáÏ ÌÏíÏ\code\" "code.c" "__Lib_Math.mcl" "__Lib_MathDouble.mcl" "__Lib_System.mcl" "__Lib_Delays.mcl" "__Lib_CType.mcl" "__Lib_CString.mcl" "__Lib_CStdlib.mcl" "__Lib_CMath.mcl" "__Lib_Conversions.mcl" "__Lib_Sprinti.mcl" "__Lib_Sprintl.mcl" "__Lib_Time.mcl" "__Lib_Trigonometry.mcl" "__Lib_Button.mcl" "__Lib_Keypad4x4.mcl" "__Lib_Manchester.mcl" "__Lib_OneWire.mcl" "__Lib_PS2.mcl" "__Lib_Sound.mcl" "__Lib_SoftI2C.mcl" "__Lib_SoftSPI.mcl" "__Lib_SoftUART.mcl" "__Lib_ADC_A_C.mcl" "__Lib_EEPROM.mcl" "__Lib_FLASH_RW.mcl" "__Lib_I2C_c34.mcl" "__Lib_PWM_c21.mcl" "__Lib_SPI_c345.mcl" "__Lib_UART_c67.mcl" "__Lib_PortExpander.mcl" "__Lib_CANSPI.mcl" "__Lib_CF.mcl" "__Lib_GlcdFonts.mcl" "__Lib_Glcd.mcl" "__Lib_LcdConsts.mcl" "__Lib_Lcd.mcl" "__Lib_RS485.mcl" "__Lib_T6963C.mcl" "__Lib_SPIGlcd.mcl" "__Lib_SPILcd.mcl" "__Lib_SPILcd8.mcl" "__Lib_SPIT6963C.mcl" "__Lib_EthEnc28j60.mcl" "__Lib_EthEnc24j600.mcl" "__Lib_TouchPanel.mcl"
0 1139 Available RAM: 352 [bytes], Available ROM: 8192 [bytes]
0 126 All files Preprocessed in 1 ms
0 122 Compilation Started code.c
29 123 Compiled Successfully code.c
0 127 All files Compiled in 63 ms
0 360 Unresolved extern 'GLCD_RST_Direction' __Lib_Glcd.c
0 360 Unresolved extern 'GLCD_RS_Direction' __Lib_Glcd.c
0 360 Unresolved extern 'GLCD_RW_Direction' __Lib_Glcd.c
0 360 Unresolved extern 'GLCD_CS2_Direction' __Lib_Glcd.c
0 360 Unresolved extern 'GLCD_RST' __Lib_Glcd.c
0 360 Unresolved extern 'GLCD_DataPort' __Lib_Glcd.c
0 360 Unresolved extern 'GLCD_RS' __Lib_Glcd.c
0 360 Unresolved extern 'GLCD_RW' __Lib_Glcd.c
0 360 Unresolved extern 'GLCD_CS2' __Lib_Glcd.c
0 360 Unresolved extern 'LCD_D7' __Lib_Lcd.c
0 360 Unresolved extern 'LCD_D6' __Lib_Lcd.c
0 360 Unresolved extern 'LCD_D5' __Lib_Lcd.c
0 360 Unresolved extern 'LCD_D4' __Lib_Lcd.c
0 360 Unresolved extern 'LCD_RS' __Lib_Lcd.c
0 360 Unresolved extern 'LCD_EN' __Lib_Lcd.c
0 102 Finished (with errors): 06 ÓÈÊãÈÑ 2012, 22:44:35 code.mcppi
i found that C file that come with it but it not in eng
  • TOPWAY-ST7565(67)-AppPro-v0.1.rar
Did you write this part of code or you took it from manual or some example?
I think, you must add some lines of code. I use mikroC also, but for AVR. But, I believe, that is very similar.
Maybe, you can find some example on mikroe.com web site for GLCD
This is how my code looks like (but, do not forget, I used EasyAVR5a development board and GLCD 128x64):
// Glcd module connections
char GLCD_DataPort at PORTC; // port for Data Bus Line
char GLCD_DataPort_Direction at DDRC; // port direction
sbit GLCD_CS1 at PORTD.B2; // Select segment 1 - 64
sbit GLCD_CS2 at PORTD.B3; // Select segment 65 - 128
sbit GLCD_RS  at PORTD.B4; // High: Data; Low: Instruction
sbit GLCD_RW  at PORTD.B5; // High: Read, Low: Write
sbit GLCD_EN  at PORTD.B6; // High: Enable signal
sbit GLCD_RST at PORTD.B7; // Reset the LCM
sbit GLCD_CS1_Direction at DDRD.B2;
sbit GLCD_CS2_Direction at DDRD.B3;
sbit GLCD_RS_Direction  at DDRD.B4;
sbit GLCD_RW_Direction  at DDRD.B5;
sbit GLCD_EN_Direction  at DDRD.B6;
sbit GLCD_RST_Direction at DDRD.B7;
// End Glcd module connections
Reactions: hesho90
    hesho90
Thank you replying
i did this code my self
the one you give me never wark becase the RST AND CS2 and more are not in my GLCD pdfs and mikroc dont want to make the code without them so how can i make the code with the ports and pins in hand
how make a GLCD code without the ports and pins that mikroc want me to give him
Now we have a clear problem. You know, mikroC intended GLCD library for 128x64 GLCD. How they said in the manual:
Graphic Lcd Library
The mikroC PRO for AVR provides a library for operating Graphic Lcd 128x64 (with commonly used Samsung KS108/KS107 controller).
For creating a custom set of Glcd images use Glcd Bitmap Editor Tool.
I take this text from manual for mikroC PRO for AVR. Please, look in manual for mikroC which you use, but I think it will write the same.
I look on the site of manufacture of your GLCD, but I did not find which controller is used in it.
I suggest you to send email for asking support and help from Mikroelektronika, or first at all, you may read manual for mikroC for GLCD library. I did not use Glcd Bitmap Editor, but I believe it is not something to complicate.
Mikroelektronika also have a forum, like this, and maybe you can find some answers on that place.
Reactions: hesho90
    hesho90
Thank you replying
but what i get from this GLCD 132x32 hard to use i try to make in seril mode if i can
i will make connet on ISIS like this
all of d0..d7 to portd of the pic and p/s and e and i dont know what ales to portb
but how is the code going to be like
and i wana Thank you for the great help you give
Ok, but I am sorry because I can not help you more.
My experience with GLCD is that part of electronic devices is not still standardise enough between manufactures. And, documentation is bad, datasheets are not good and helpful enough for begginers, like microcontroller datasheets are. When I try to find some examples of libraries for my GLCD on the internet, I had not any success. And, I give up, and start to use mikroe library, I just did not know how to write the library.
Best regard!
