[SOLVED] mikro c button function code is not working
how to declear port D of pic16f877a as input??? kindly guide me about this.... i have decleard it as :
#define enter PORTD.F0
AND
TRISD.F0=1;
IS this a true declearation???
kindly check my code for errors.... if no errors found then plz compile it for me i think my compiler is not making true hex file....
// OUTPUTS
#define gen_cont PORTE.f2
#define led PORTB.f2
#define main_cont PORTC.F0
#define chowk PORTC.F1
#define ignition PORTC.F2
#define self PORTC.F3
// INPUTS
#define genr PORTA.F0
#define mains PORTA.F1
//.........button connections..........
#define reset PORTD.F1
#define up PORTD.F2
#define down PORTD.F3
//CONSTANTS
#define t 100   //DELAYS
#define P 1     //FOR MAIN AND gen INPUTS
#define A 0     //FOR MAIN AND gen INPUTS
#define ms 150   // for button debounce
//============Start LCD Connections========================================
sbit LCD_RS at RD5_bit;
sbit LCD_EN at RD4_bit;
sbit LCD_D4 at RC4_bit;
sbit LCD_D5 at RC5_bit;
sbit LCD_D6 at RC6_bit;
sbit LCD_D7 at RC7_bit;
sbit LCD_RS_Direction at TRISD5_bit;
sbit LCD_EN_Direction at TRISD4_bit;
sbit LCD_D4_Direction at TRISC4_bit;
sbit LCD_D5_Direction at TRISC5_bit;
sbit LCD_D6_Direction at TRISC6_bit;
sbit LCD_D7_Direction at TRISC7_bit;
//=======End LCD Connections=============================================
//============= START RAM SAVER ===========================================
const char wu[] = "Warming up.....";
const char fv[] = "Frequency  Volts";
const char error[] = "< ERROR >";
const char f2s[] = "Fails to start";
const char st[] = "Shenztech";
const char pl[] = "Pvt Ltd";
const char mna[] = "Mains not avail";
const char sg[] = "Starting Genset";
const char mok[] = "Mains OK..";
const char mol[] = "Mains Overload";
const char pw[] = "Please Wait...";
const char gwt[] = "Gen Warm up time";
const char sont[] = "Self ON Time";
const char soft[] = "Self OFF time";
const char ep[] = "Enter Passward";
const char asteric[] = "*";
const char sp[] = "scroll please";
const char sav[] = "Saving.......";
//============= END RAM SAVER ===========================================
 int x=0, inc=0, opt=1, gen_wt=10, self_ont=2, self_oft=5;
 char string[7]; // to dispaly integers stored in eeprom
char msg[17]; //declare array set 16 bytes of RAM aside for copying into
 // copy const to ram string
char  *CopyConst2Ram(char * dest, const char * src)
  char * d ;
  d = dest;
  for(;*dest++ = *src++;);
  return d;
 unsigned char cnt;
 void gen(void);
void start(void);
int scroll_up( int opt, int inc);
int scroll_down( int opt, int inc );
void interrupt()
     if(TMR0IF_bit)
     {  cnt++;
        TMR0IF_bit=0;
        if(cnt>=10)
           led=~led;
           cnt=0;
       TMR0=0;
  //-----------------------scroll up ...........................................
     scroll_up(int opt ,int inc )
       int j=1;
       inc++;
             if(opt==1)
                 Lcd_Cmd(_LCD_CLEAR);                    // Clear display
                 Lcd_Cmd(_LCD_CURSOR_OFF);
                 Lcd_Cmd(_LCD_MOVE_CURSOR_RIGHT);
                        if(inc==0)
                         Lcd_Out(1,1,CopyConst2Ram(msg,gwt));
                          if(inc==1)
                         Lcd_Out(1,1,CopyConst2Ram(msg,sont));
                          if(inc==2)
                         Lcd_Out(1,1,CopyConst2Ram(msg,soft));
             } //end  if opt = 1
             if(opt==0)
             //..................inc=0...gen_wt...............................
                        if(inc==0)
                           x=gen_wt;
                          IntToStr(x, string);
                                     Lcd_Out(2,10,string);
                           do
                               if((enter==1) && (reset==1) && (up==0) && (down==1) && j==1)//(Button(&PORTD,2,ms,0)&&j) // up pressed
                                 {   Delay_ms(ms); // wait for switch debounce
                                     x++;
                                     Delay_ms(500);
                                 }// end if
                                                   if((enter==0) && (reset==1) && (up==1) && (down==1))//( Button(&PORTD,0,ms,0)) //Enter pressed to save
                                                       gen_wt=x;
                                                        Delay_ms(500);
                                                        Lcd_Out(1,1,CopyConst2Ram(msg,sav));
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=0
                  //....................inc = 1......self_ont..............
                   if(inc==1)
                           x=self_ont;
                           do
                                     x++;
                                     Delay_ms(500);
                                 }// end if
                                                        self_ont=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=1
                  //.....................inc=2................self_oft..................................
                   if(inc==2)
                           x=self_oft;
                           do
                                     x++;
                                     Delay_ms(500);
                                 }// end if
                                                       self_oft=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                                                     inc=0;
                        } while(j);
                  }// if inc=2
             } // if opt = 0
              return (inc);
     } // end scroll up
 //-----------------------scroll Down ...........................................
     scroll_down( int opt , int inc )
       int j=1;
       inc--;
             if(opt==1)
                        if(inc==0)
                         if(inc==1)
                          if(inc==2)
             } //end  if opt = 1
             if(opt==0)
               //..................inc=0....gen_wt......................
                        if(inc==0)
                           x=gen_wt;
                           do
                               if((enter==1) && (reset==1) && (up==1) && (down==0) && j==1)//(Button(&PORTD,2,ms,0)&&j) // down pressed
                                     x--;
                                     Delay_ms(500);
                                 }// end if
                                                        gen_wt=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=0
                   if(inc==1)
                           x=self_ont;
                           do
                                     x--;
                                     Delay_ms(500);
                                 }// end if
                                                        self_ont=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=1
                  //.................inc=2..........self_oft..................................
                   if(inc==2)
                           x=self_oft;
                           do
                                     x--;
                                     Delay_ms(500);
                                 }// end if
                                                       self_oft=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                                                     inc=0;
                        } while(j);
                  }// if inc=2
             } // if opt = 0
             return (inc);
     } // end scroll down
//..............generator routine...............................................
gen()
      int i;
     main_cont=0;
      ignition=1;
      Delay_ms(2000);
      chowk=1;
      Delay_ms(5000);//chowk on for 5 seconds
      chowk=0;
      for(i=0; i<3; i++)
               if(mains==P)     //if Main resumes
                 i=3;
                 gen_cont=0;
                 ignition=0;
                 self=0;
                 Delay_ms(2000);  //self on for 2 seconds
                 main_cont=1;
               if(i==2)
                   chowk=1;
                   chowk=0;
       self=1;
       self=0;
       Delay_ms(4000);  //self off for 4 seconds
             if(genr==P)     //if generator ON
                 i=3;
      if(genr==P && mains==A)     // if generator ON
       Delay_ms(1000);
      Lcd_Out(1,1,CopyConst2Ram(msg,wu));   // Write text in first row
       Delay_ms(5000);
       gen_cont=1;      // transfer load on genset after warmup
      Delay_ms(300);
      Lcd_Out(1,1,CopyConst2Ram(msg,fv));   // Write text in first row
      Lcd_Out(2,1," . Hz     . V");
      // lcd_init();
      Delay_ms(2000);
      else
      if(genr==A && mains==A)    // if generator is still off; i.e; can't start
      Delay_ms(1000);
      Lcd_Out(1,2,CopyConst2Ram(msg,error));
      Lcd_Out(2,1,CopyConst2Ram(msg,f2s));   // Write text in first row
      ignition=0;        //Turn off the genset
      main_cont=0;
      while(mains==A && genr==A); //stuck here untill reset/restart the controller board (IF main and generator both are absent)
      for(;mains==A;)   //untill main absent
          if (mains==A)      // if main absent
            gen_cont=1;     // Turn on generator contactor
            main_cont=0;    // Turn off main contactor
            while(mains==A); // stay here until main resumes
         if (mains==P)       //if main presents or after main resumes
             gen_cont=0;
             Delay_ms(1000);
             Delay_ms(2000);
             main_cont=1;
             Lcd_Out(1,3,CopyConst2Ram(msg,st));   // Write text in first row
             Lcd_Out(2,4,CopyConst2Ram(msg,pl));
void start()
  gen_cont=0;
      main_cont=0;
      Lcd_Out(1,1,CopyConst2Ram(msg,mok));   // Write text in first row
      Lcd_Out(2,1,CopyConst2Ram(msg,pw));    //please wait
      Delay_ms(3000);
      main_cont=1;
      Lcd_Out(2,1,CopyConst2Ram(msg,mol));    //mains overload
         Delay_ms(2000);
         Lcd_Cmd(_LCD_CURSOR_OFF);               // Cursor off
         Lcd_Out(2,4,CopyConst2Ram(msg,pl));   //pvt ltd
void main()
    unsigned int i=0, itrue=1;  //i=loops ; x=passward ; J=While lock
 //..............INITIALIZATIONS............................................
  // CONFIGURING SFRs:
  cnt=0;
  TMR0=0;   // loading vlaue of timer0 interrupt
  OPTION_REG=0x87;  // for timer 0; presscaller 1; 256
  ADCON1=0x06;   // adc reg initialization
  INTCON=0xA0;  // for timer0  ; interrupt reg initilization
  // OUTPUTS:
  TRISB.f2 = 0;   //led out put
  TRISE.F2=0;        // gen cont output
  TRISC=0x00;        // portC output For LCD
  PORTC=0X00;        //  initilization port c
  // INPUTS:
  TRISD.F0=1;    // ENTER
  TRISD.F1=1;  // RESET
  TRISD.F2=1;    // UP
  TRISD.F3=1;   // DOWN   */
  TRISA = 0xFF;     // port A as input
  //TRISD = 0xFF;     // port D as input
    // TRISD.F4=0XFF;      ALREADY DIRECTED AT LCD INITILIZATION
    //  TRISD.F5=0XFF;
  lcd_init();
  Delay_ms(500);
    if(mains==P)    // if main is Present.
       start();
  while(1)
                    if ((enter==0) && (reset==1) && (up==1) && (down==1))// (Button(&PORTD,0,ms,0))  //when Enter is pressed
                          itrue=1;
                          x=0;
                          Lcd_Out(1,1,CopyConst2Ram(msg,ep));   //enter passward
                          delay_ms(t);
                             while ((enter==0) && (reset==1) && (up==1) && (down==1))//(Button(&PORTD,0,ms,0)) // press enter
                                 x++;
                               Lcd_Out(2,x,CopyConst2Ram(msg,asteric));  //*
                                 if(x==4)
                                   Lcd_Out(1,1,CopyConst2Ram(msg,pw));   //please wait
                                   Delay_ms(1000);
                                   Lcd_Out(1,1,CopyConst2Ram(msg,gwt));  // Generator warm up time
                                   inc=0;  //for selection of variable
                                   itrue=1;   // Entring and Exiting main menu
                                   opt=1;    // option b/w selection number or variable
                                             while(itrue==1)
                                                  if ((enter==0) && (reset==1) && (up==1) && (down==1))//(Button(&PORTD,0,ms,0))  // pressing enter to enter time
                                                   opt=0;
                                                   Lcd_Out(2,1,CopyConst2Ram(msg,sp));
                                                  if ((enter==1) && (reset==0) && (up==1) && (down==1))//(Button(&PORTD,1,ms,0)) //press reset to exit
                                                     itrue=0;
                                                  if ((enter==1) && (reset==1) && (up==0) && (down==1))//(Button(&PORTD,2,ms,0))  //up
                                                      inc=scroll_up(opt,inc);
                                                  if ((enter==1) && (reset==1) && (up==1) && (down==0))//(Button(&PORTD,3,ms,0))   // down
                                                      inc=scroll_down(opt,inc);
                                              x++;
                                 }   //if
                             }    //while
                          Delay_ms(1000);
    if(mains==A)    // if main is absent.
     Delay_ms(4000); // wait for 4 seconds to ensure power failure
    if(mains==P)     //check again
      continue;
     //Delay_ms(1000);
     Lcd_Out(1,1,CopyConst2Ram(msg,mna));    //mains not available
     Lcd_Out(2,1,CopyConst2Ram(msg,sg));     //starting genset
     Delay_ms(1000);
     gen();
    else           // if main is present .........
      Lcd_Out(2,1,CopyConst2Ram(msg,mol));    // mains overload
      Delay_ms(2000);
     //  gen_cont=0;   //Turn off generator contactor
       //main_cont=1;   //Turn on main contactor
      Lcd_Out(2,4,CopyConst2Ram(msg,pl));     // pvt ltd
      Delay_ms(1000);
              for(i=0; i<96; i++)
                       Lcd_Cmd(_LCD_SHIFT_RIGHT);
                       Delay_ms(t);
                        if (enter==0)
                            i=96;
                        if(mains==A)
                          i=96;
   }    // while
}      // main
// OUTPUTS
// INPUTS
#define up PORTD.F2
//CONSTANTS
  char * d ;
  d = dest;
  return d;
 unsigned char cnt;
 void gen(void);
void start(void);
void interrupt()
     if(TMR0IF_bit)
     {  cnt++;
        TMR0IF_bit=0;
        if(cnt>=10)
           led=~led;
           cnt=0;
       TMR0=0;
       int j=1;
       inc++;
             if(opt==1)
                        if(inc==0)
                          if(inc==1)
                          if(inc==2)
             } //end  if opt = 1
             if(opt==0)
                        if(inc==0)
                           x=gen_wt;
                           do
                                     x++;
                                     Delay_ms(500);
                                 }// end if
                                                       gen_wt=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=0
                   if(inc==1)
                           x=self_ont;
                           do
                                     x++;
                                     Delay_ms(500);
                                 }// end if
                                                        self_ont=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=1
                   if(inc==2)
                           x=self_oft;
                           do
                                     x++;
                                     Delay_ms(500);
                                 }// end if
                                                       self_oft=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                                                     inc=0;
                        } while(j);
                  }// if inc=2
             } // if opt = 0
              return (inc);
     } // end scroll up
       int j=1;
       inc--;
             if(opt==1)
                        if(inc==0)
                         if(inc==1)
                          if(inc==2)
             } //end  if opt = 1
             if(opt==0)
                        if(inc==0)
                           x=gen_wt;
                           do
                                     x--;
                                     Delay_ms(500);
                                 }// end if
                                                        gen_wt=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=0
                   if(inc==1)
                           x=self_ont;
                           do
                                     x--;
                                     Delay_ms(500);
                                 }// end if
                                                        self_ont=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=1
                   if(inc==2)
                           x=self_oft;
                           do
                                     x--;
                                     Delay_ms(500);
                                 }// end if
                                                       self_oft=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                                                     inc=0;
                        } while(j);
                  }// if inc=2
             } // if opt = 0
             return (inc);
gen()
      int i;
     main_cont=0;
      ignition=1;
      Delay_ms(2000);
      chowk=1;
      chowk=0;
      for(i=0; i<3; i++)
                 i=3;
                 gen_cont=0;
                 ignition=0;
                 self=0;
                 main_cont=1;
               if(i==2)
                   chowk=1;
                   chowk=0;
       self=1;
       self=0;
                 i=3;
       Delay_ms(1000);
       Delay_ms(5000);
      Delay_ms(300);
      // lcd_init();
      Delay_ms(2000);
      else
      Delay_ms(1000);
      main_cont=0;
             gen_cont=0;
             Delay_ms(1000);
             Delay_ms(2000);
             main_cont=1;
void start()
  gen_cont=0;
      main_cont=0;
      Delay_ms(3000);
      main_cont=1;
         Delay_ms(2000);
void main()
  cnt=0;
  // OUTPUTS:
  // INPUTS:
  TRISD.F2=1;    // UP
    //  TRISD.F5=0XFF;
  lcd_init();
  Delay_ms(500);
       start();
  while(1)
                          itrue=1;
                          x=0;
                          delay_ms(t);
                                 x++;
                                 if(x==4)
                                   Delay_ms(1000);
                                             while(itrue==1)
                                                   opt=0;
                                                     itrue=0;
                                              x++;
                                 }   //if
                             }    //while
                          Delay_ms(1000);
      continue;
     //Delay_ms(1000);
     Delay_ms(1000);
     gen();
      Delay_ms(2000);
      Delay_ms(1000);
              for(i=0; i<96; i++)
                       Delay_ms(t);
                        if (enter==0)
                            i=96;
                        if(mains==A)
                          i=96;
   }    // while
}      // main
// OUTPUTS
// INPUTS
#define up PORTD.F2
//CONSTANTS
  char * d ;
  d = dest;
  return d;
 unsigned char cnt;
 void gen(void);
void start(void);
void interrupt()
     if(TMR0IF_bit)
     {  cnt++;
        TMR0IF_bit=0;
        if(cnt>=10)
           led=~led;
           cnt=0;
       TMR0=0;
       int j=1;
       inc++;
             if(opt==1)
                        if(inc==0)
                          if(inc==1)
                          if(inc==2)
             } //end  if opt = 1
             if(opt==0)
                        if(inc==0)
                           x=gen_wt;
                           do
                                     x++;
                                     Delay_ms(500);
                                 }// end if
                                                       gen_wt=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=0
                   if(inc==1)
                           x=self_ont;
                           do
                                     x++;
                                     Delay_ms(500);
                                 }// end if
                                                        self_ont=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=1
                   if(inc==2)
                           x=self_oft;
                           do
                                     x++;
                                     Delay_ms(500);
                                 }// end if
                                                       self_oft=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                                                     inc=0;
                        } while(j);
                  }// if inc=2
             } // if opt = 0
              return (inc);
     } // end scroll up
       int j=1;
       inc--;
             if(opt==1)
                        if(inc==0)
                         if(inc==1)
                          if(inc==2)
             } //end  if opt = 1
             if(opt==0)
                        if(inc==0)
                           x=gen_wt;
                           do
                                     x--;
                                     Delay_ms(500);
                                 }// end if
                                                        gen_wt=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=0
                   if(inc==1)
                           x=self_ont;
                           do
                                     x--;
                                     Delay_ms(500);
                                 }// end if
                                                        self_ont=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                        } while(j);
                  }// if inc=1
                   if(inc==2)
                           x=self_oft;
                           do
                                     x--;
                                     Delay_ms(500);
                                 }// end if
                                                       self_oft=x;
                                                        Delay_ms(500);
                                                        Delay_ms(1000);
                                                        j=0;
                                                     } // end saving
                                                     inc=0;
                        } while(j);
                  }// if inc=2
             } // if opt = 0
             return (inc);
gen()
      int i;
     main_cont=0;
      ignition=1;
      Delay_ms(2000);
      chowk=1;
      chowk=0;
      for(i=0; i<3; i++)
                 i=3;
                 gen_cont=0;
                 ignition=0;
                 self=0;
                 main_cont=1;
               if(i==2)
                   chowk=1;
                   chowk=0;
       self=1;
       self=0;
                 i=3;
       Delay_ms(1000);
       Delay_ms(5000);
      Delay_ms(300);
      // lcd_init();
      Delay_ms(2000);
      else
      Delay_ms(1000);
      main_cont=0;
             gen_cont=0;
             Delay_ms(1000);
             Delay_ms(2000);
             main_cont=1;
void start()
  gen_cont=0;
      main_cont=0;
      Delay_ms(3000);
      main_cont=1;
         Delay_ms(2000);
void main()
  cnt=0;
  // OUTPUTS:
  // INPUTS:
  TRISD.F2=1;    // UP
    //  TRISD.F5=0XFF;
  lcd_init();
  Delay_ms(500);
       start();
  while(1)
                          itrue=1;
                          x=0;
                          delay_ms(t);
                                 x++;
                                 if(x==4)
                                   Delay_ms(1000);
                                             while(itrue==1)
                                                   opt=0;
                                                     itrue=0;
                                              x++;
                                 }   //if
                             }    //while
                          Delay_ms(1000);
      continue;
     //Delay_ms(1000);
     Delay_ms(1000);
     gen();
      Delay_ms(2000);
      Delay_ms(1000);
              for(i=0; i<96; i++)
                       Delay_ms(t);
                        if (enter==0)
                            i=96;
                        if(mains==A)
                          i=96;
   }    // while
}      // main
No. I haven't done any changes in the code. But it is not working for me.
Which version of mikroC are you using?
i am using the latest version micro c pro for pic v5.6.1.
I have checked it out.... it is nothing but purely my compiler problem. i am going to reinstall the whole program. BTW which version are you using??
I am using both mikroC 5.6.0 and 5.6.1. If you need the file which creates the right hex file, PM me your email address. I will send the file.
Thank you very much internetuser2k12. i have reinstalled the software and the problem is solved :) .. now it is compiling the true hex file. i am again very thankful to you for your kind help :)
