Simulation of CB-CPW on ADS momentum in the W band
Shehata
Member level 3
Member level 3
Waterloo, Ontario, Canada
Hi
I am trying to simulate CB-CPW on ADS momentum. I am a bit worried about the ground port definition in momentum. Any clue?
Slot line are created using slot definition to the layer mapping in substrate editor. Its a negative artwork. your can follow following steps to create your design
1) Create a design negative to your desired design(remember you need to create design of the vacant slots in layout using draw polygon/rectangle option)
2) Now map the layer in substrate as slot.
3) Now View the structure in 3D Viewer, the viewer should show the desired design.
Amit
ADVERTISING LINK REMOVED
Thanks a lot!
I want also to add that this type of simulation agrees with HFSS if you make sure that the modes are slot e.g. no parallel plate modes
Attached is a snapshot for a simple CPW line. The figure shows the agreement between HFSS and momentum
You can also cross check with ADS FEM, the results would be same.
