How to export a HFSS file to CST format?
sanaz.mr
hi
I want to export file .hfss to file of cst (from hfss to cst), but i don't know to do it
plz tell me how to export it
tnx
Re: export from hfss to cst
hi
tnx
I don't think you can.
I export jpg file from HFSS and import it in CST.
I' interested in that. What can you do with the file in CST? JPEG is a lossy compression method, so its not clear to me how that will help you simulate anything, but perhaps I am mistaken. I don't use CST, but I'm very surprised it supports JPEG import.
The usual file format for such data exchange is the *.sat format.
This includes the 3D geometries, but does not include material properties.
IGES, STEP and DXF should as well be available in both simulators. If you have cracked versions, you may have to struggle a bit for exporting and importing.
If the structure is simple, its best to redraw the same.
I would prefer *.sat over IGES, STEP and DXF because *.sat format is the "native" 3D format of the ACIS drawing kernel that both simulators use.
you can export your HFSS design using ansoft geometry formats *.sm2 or *.sm3
hi
tnx
You can also ask help from Ansoft and CST technical support. ^^,
