progrmming logic for vhdl
gauree
Newbie level 1
Newbie level 1
hi...
i want to know the logic for written the program in vhdl for continuously rolling LED's.
You have to -shift- some data.
Some pseudo code:
signal  LEDS : std_logic_vector(7 downto 0);
LEDS <= LEDS(0) & LEDS(7 downto 1);  -- Rotate
Reactions: gauree
    gauree
The easiest and most flexible way to do that is to design a FSM, in which each state defines which are the LEDs to turn on and which to turn off. In this way you can create any desired pattern just by changing the next-state logic. Be aware of the frequency of states change, since human eye would not see any change if this frequency is too high.
Cheers
Reactions: gauree
    gauree
