malkomx
Newbie level 6
Hi All,
I'm working on ungrounded CPW structure. I've been through all previous post about CPW , how to feed it and Ansoft tutorials,and I designed a cpw antenna with SMA. From Antenna_kit released by ansoft I realized that the length of the coax should be Lambda/6. So I simulated my CPW with 4 different feeding, 1.SMA with Lambda/6 length, 2. SMA with short length, 3. Wave port as recommended by some tutorials (width=3(2*s+w) and height=4*h) and finally 4. lumped port as I've seen in some examples.
But the problem is I've got 4 DIFFERENT results by 4 different feeding. For better understanding I attached the HFSS file.
I wonder if anybody could help me and tell me which result is correct?
