Altium 10: How do i set the design rules.
grizedale
Advanced Member level 3
How do i find the list of design rules so that i can set them?...............i mean, i should be able to find a list like this, surely?.....
1....pad to pad clearance
2....pad to via clearance
3....via to via clearance
4.....track to board edge
5...via to board edge
etc etc etc......
GO through PCB-->design--> Rules here we can enble all those options,then generate DRC it will shows all these errors.
ive been there but i cant find this list.....i can just find the odd one or two..................i am wondering if my company have not payed the license fee and therefore i am not seeing the full quota?
:) not like that evary one having all those options, see below image. Are u able to see below image in your system
Untitled.png see this one in ur system
Hi Grizedale,
You want to set different clearance rule for all above mentioned?
If so,
1)Pad to pad you can create pad class(Design/classes/pad classes)
2) and 3) I think the same pad class rule is applied to vias also,i am not sure(just try it once)
otherwise you can use query builder and query helper in design rules to pass different kind of rules.
4) and 5) For this also you can use query builder and query helper.
Try these things.
