[SOLVED] .pcb file can not open
i_engineer
hi everyone !
i have download Literature TVP5158EVM Schematic and PCB Rev 1_2 from link,**broken link removed**
and try to open a layout file name with EES-157-V1.2_Final.pcb from folder, but i cannot open it in OrCAD Layout plus or altium DXP
can anybody guide me how to open it ,is there any special software for that or any special steps to open it in Orcad
i_engineer
.DSN file is orcad file. In ALTIUM open FILE --> IMport wizard ,there itself just sect the ORCAD Designers and then add .DSN file, then it will be open.
P-CAD also has .pcb extension for pcb file, if you are using altium then select pcad importer settings and try to import it.
