fouwad
Full Member level 4
hi, i am posting my code as well as my simulation results of ALU, can anyone plz let me know what is causing this unusual simulation results and what can be done to get the desired results.
here the results are achieved after quite a number of clockcycles, what in code is responsible for such strange delays
module ALU( clk,Iid2alu, rs1_data, rs2_data, rd_addr, imm_value, alu_out, rd_data_mem, rd_addr_latched, Ialu2mem
input clk;
input [0:31] rs1_data;
input [0:31] rs2_data;
input [0:4] rd_addr;
input [0:31]imm_value;
input [0:31]Iid2alu;
output reg [0:31]alu_out;
output reg[0:31]rd_data_mem;
output reg[0:4]rd_addr_latched;
output reg [0:7] Ialu2mem;
//g [0:7]csr; // current status register
reg [0:31]alu_result;
reg [0:31]rd_data_mem_val;
reg [0:31] rtype_rslt;
reg [0:31] immtype_rslt;
wire [0:31] A;
wire [0:31] B;
wire [0:31] imm;
wire [0:5] op;
wire [0:4]rd_addr;
wire [0:5] func;
////concatination for 31 to 7 bit reduced values
//assign A={24'b0,rs1_data};
//assign B={24'b0,rs2_data};
//assign imm={24'b0,imm_value};
wire [0:31] add_rslt; //result of addition
wire [0:31] add_rslt_imm; //result of addition with immediate value
wire [0:31] sub_rslt;
wire [0:31] sub_rslt_imm;
//wire [0:32] awc_rslt;
//wire sel_mux; // sel line for mux
wire [0:31] i; // instruction
wire isLB; //DATA TRANSFER
wire isLH;
wire isLW;
wire isSB;
wire isSH;
wire isSW;
wire isMOVS2I;
wire isMOVI2S;
wire isADD; //ARTHIMETIC
wire isADDI;
wire isSUB;
wire isSUBI;
wire isAWC;
wire isINC;
wire isDEC;
wire isAND; //LOGICAL
wire isANDI;
wire isOR;
wire isORI;
wire isXOR;
wire isXORI;
wire isSLL; //SHIFT
wire isSLLI;
wire isSRL;
wire isSRLI;
wire isCLR; //TEST SET
wire isSET;
wire isSLT;
wire isSLTI;
wire isSGT;
wire isSGTI;
wire isSLE;
wire isSLEI;
wire isSGE;
wire isSGEI;
wire isSEQ;
wire isSEQI;
wire isSNE;
wire isSNEI;
wire set_lt;
wire set_gt;
wire set_le;
wire set_ge;
wire set_eq;
wire set_ne;
wire set_lt_imm;
wire set_gt_imm;
wire set_le_imm;
wire set_ge_imm;
wire set_eq_imm;
wire set_ne_imm;
wire ld_st_off_calc;
wire isRtype;
wire isImmtype;
assign i=Iid2alu;
assign op= i[0:5];
assign func= i[26:31];
//assign rd_addr= i[16:20];
assign A=rs1_data;
assign B= rs2_data;
assign imm=imm_value;
assign isRtype = (op== 6'b000000);
assign isImmtype = (op!=6'b000000);
assign isLB = (op == 6'b100000);
assign isLH = (op == 6'b100001);
assign isLW = (op == 6'b100011);
assign isSB = (op == 6'b101000);
assign isSH = (op == 6'b101001);
assign isSW = (op == 6'b101011);
assign isADD = (op == 6'b000000) && (func == 6'b010000);
assign isADDI = (op == 6'b001000);
assign isSUB = (op == 6'b000000) && (func == 6'b010001);
assign isSUBI = (op == 6'b001001);
assign isAWC = (op == 6'b000000) && (func == 6'b010100);
assign isINC = (op == 6'b000000) && (func == 6'b010010);
assign isDEC = (op == 6'b000000) && (func == 6'b010011);
assign isAND = (op == 6'b000000) && (func == 6'b010101);
assign isANDI = (op == 6'b001100);
assign isOR = (op == 6'b000000) && (func == 6'b010110);
assign isORI = (op == 6'b001101);
assign isXOR = (op == 6'b000000) && (func == 6'b010111);
assign isORI = (op == 6'b001110);
assign isSLL = (op == 6'b000000) && (func == 6'b000000);
assign isSLLA = (op == 6'b000000) && (func == 6'b000001);
assign isSRL = (op == 6'b000000) && (func == 6'b000010);
assign isSRLA = (op == 6'b000000) && (func == 6'b000011);
// SLLI SRLI TO BE ADDED
assign isCLR = (op == 6'b000000) && (func == 6'b101000);
assign isSET = (op == 6'b000000) && (func == 6'b101001);
assign isSLT = (op == 6'b000000) && (func == 6'b101010);
assign isSLTI = (op == 6'b011000);
assign isSGT = (op == 6'b000000) && (func == 6'b101011);
assign isSGTI = (op == 6'b011001);
assign isSLE = (op == 6'b000000) && (func == 6'b101100);
assign isSLEI = (op == 6'b011010);
assign isSGE = (op == 6'b000000) && (func == 6'b101101);
assign isSGEI = (op == 6'b011011);
assign isSEQ = (op == 6'b000000) && (func == 6'b101110);
assign isSEQI = (op == 6'b011100);
assign isSNE = (op == 6'b000000) && (func == 6'b101111);
assign isSNEI = (op == 6'b011101);
assign add_rslt= A+B;
assign add_rslt_imm= A+imm;
assign sub_rslt=A-B;
assign sub_rslt_imm= A-imm;
//sign awc_rslt=A+B;
assign ld_st_off_calc=A+imm;
assign leftShiftAmount = rs2_data[27:31];
assign leftShiftResult = rs1_data << leftShiftAmount;
assign rightShiftAmount = rs2_data[27:31];
assign rightShiftResult = rs1_data << rightShiftAmount;
assign set_lt= (A<B);
assign set_gt= (A>B);
assign set_le= (A<=B);
assign set_ge= (A>=B);
assign set_eq= (A==B);
assign set_ne= (A!=B);
assign set_lt_imm= (A<imm);
assign set_gt_imm= (A>imm);
assign set_le_imm= (A<=imm);
assign set_ge_imm= (A>=imm);
assign set_eq_imm= (A==imm);
assign set_ne_imm= (A!=imm);
/* always @ (isADD or isADDI or isSUB or isSUBI or add_rslt or add_rslt_imm or sub_rslt or sub_rslt_imm )
begin
casex ({isADD, isADDI, isSUB, isSUBI}) /* $s full_case parallel_case */
/* 6'b000000 : addResult = 32'bx;
6'b1xxxxx : addResult = rsPrt;
6'bx1xxxx : addResult = rsPimm;
6'bxx1xxx : addResult = rsPimm;
6'bxxx1xx : addResult = rsPrt;
6'bxxxx1x : addResult = rsMrt;
6'bxxxxx1 : addResult = rsMrt;
endcase // casex({isADD, isADDI, isADDIU, isADDU, isSUB, isSUBU})
end // always @ (...
always @(isRtype or A or B or func or leftShiftResult or rightShiftResult or add_rslt, sub_rslt or set_lt or set_gt or set_le or set_ge
or set_eq or set_ne )
begin
if(isRtype)
begin
case(func)
6'b000000: rtype_rslt = leftShiftResult;
6'b000001: rtype_rslt = rightShiftResult;
6'b100000: rtype_rslt = add_rslt;
6'b100001: rtype_rslt = sub_rslt;
// 6'b100010: rtype_rslt =
// 6'b100011:
// 6'b100100: rtype_rslt = A
6'b100101: rtype_rslt = A & B ;
6'b100110: rtype_rslt = A | B;
6'b100111: rtype_rslt = A^ B;
6'b101000: rtype_rslt = 32'b00000000;
6'b101001: rtype_rslt = 32'b00000001;
6'b101010: rtype_rslt = set_lt? {31'b0, 1'b1} : 32'b0;
6'b101011: rtype_rslt = set_gt? {31'b0, 1'b1} : 32'b0;
6'b101100: rtype_rslt = set_le? {31'b0, 1'b1} : 32'b0;
6'b101101: rtype_rslt = set_ge? {31'b0, 1'b1} : 32'b0;
6'b101110: rtype_rslt = set_eq? {31'b0, 1'b1} : 32'b0;
6'b101111: rtype_rslt = set_ne? {31'b0, 1'b1} : 32'b0;
// 6'b000111:
// 6'b000000:
default : rtype_rslt = 32'bxxxxxxxx;
endcase
end
else
end
always @(B or op)
begin
if(op==6'b101000 || op==6'b101010 || op==6'b101011)
rd_data_mem_val = B; //incase of store type inst
else
rd_data_mem_val = 32'hxxxxxxxx;
end
always @ (isImmtype or A or op or add_rslt_imm, sub_rslt_imm or set_lt_imm or set_gt_imm or set_le_imm or set_ge_imm or
set_eq_imm or set_ne_imm or ld_st_off_calc or imm)
/* leftShiftResult,rightShiftResult or add_rslt or sub_rslt or or imm) /*
or set_lt or set_gt or add_rslt_imm or sub_rslt_imm or imm)*/
begin
if(isImmtype)
begin
case(op)
6'b001000: immtype_rslt= add_rslt_imm;
6'b001001: immtype_rslt= sub_rslt_imm;
6'b001100: immtype_rslt= A & imm;
6'b001101: immtype_rslt= A | imm;
6'b001110: immtype_rslt= A ^ imm;
6'b011000: immtype_rslt= 32'h00000000;
6'b011001: immtype_rslt= 32'h00000001;
6'b011010: immtype_rslt= set_lt_imm? {31'b0, 1'b1} : 32'b0;
6'b011011: immtype_rslt= set_gt_imm? {31'b0, 1'b1} : 32'b0;
6'b011100: immtype_rslt= set_le_imm? {31'b0, 1'b1} : 32'b0;
6'b011101: immtype_rslt= set_ge_imm? {31'b0, 1'b1} : 32'b0;
6'b011110: immtype_rslt= set_eq_imm? {31'b0, 1'b1} : 32'b0;
6'b011111: immtype_rslt= set_ne_imm? {31'b0, 1'b1} : 32'b0;
6'b100000: immtype_rslt= ld_st_off_calc;
6'b100001: immtype_rslt= ld_st_off_calc;
6'b100011: immtype_rslt= ld_st_off_calc;
6'b101000: immtype_rslt= ld_st_off_calc;
6'b101001: immtype_rslt= ld_st_off_calc;
6'b101011: immtype_rslt= ld_st_off_calc;
default: immtype_rslt= 32'hxxxxxxxx;
endcase
end
else
end
always @(isRtype or rtype_rslt or immtype_rslt or isImmtype)
if(isRtype)
alu_result= rtype_rslt;
else if(isImmtype)
alu_result= immtype_rslt;
else
alu_result= 32'hxxxxxxxx;
always @ (posedge clk)
begin
alu_out <= alu_result;
rd_addr_latched <= rd_addr;
Ialu2mem <= Iid2alu[24:31];
rd_data_mem <= rd_data_mem_val;
end
endmodule
