Barry, thank you. I actually want to test the Impedance vs. Frequency characteristic. As we known, the equivalent circuit of inductor is a inductor parallel with capacitor, then series with a resistor. I particularly care the parallel resonant frequency and the impedance at nearby this frequency.
Sorry, that won't work.You can just connect the inductor to a function generator and also to an ohmmeter of a multimeter. As you increase the frequency of the signal, the resistance should increase, so it's a frequency response testing.
That article is wrong. In fact the whole website is not very good.Check out the resource below, as it contains a circuit and explanation of this circuit:
http://www.learningaboutelectronics.com/Articles/How-to-test-an-inductor
