Tan and ArcTan calculation
baby_1
Advanced Member level 1
Hello
Could you help me to solve this problem? i want to find w
Hello Baby_1
the answer is w=10000*sqrt(230).
Hope helps.
Cheers
Reactions: baby_1
    baby_1
By trial and error, w = about 154000
I have no idea how to calculate it. What's this for?
This looks like the start of a phase margin calculation.
Usually trail and error or plot it in MATLAB and read it off or use MATLAB's solve functions.
Reactions: baby_1
    baby_1
How did you work that out?:???:
(I agree with the answer)
Oh, right - for poles at 10KHz, 100KHz and 200KHz.
I'd just use a simulator (or spreadsheet), but I'd still be interested to hear how Hakeen did the calculation.
I would also want to know how hakeen did it, this might help to eliminate the tedious trail and error method.
Please post master hakeen:smile:
Hello hakeen
it is completely right.
could you write the answer completely ? how did you find it ? it has a formula to solve these equation ?
i want to calculate an amplifier G.M(Gain Margin) and P.M(Phase margin)
Hello
thanks for good posts, but I am not math-master.
Anyway, for solution two important things
1)arctan x + arctan y = arctan ( (x+y)/(1-x*y))
2)arctan(x) = -pi --> x=0
so think it is x=w/10^4 then
[arctan(x)+arctan(x/10)]+arctan(x/20) = -pi
so from 1&2
x= sqrt(230) and w= sqrt(230)*10^4
Hope helps.
Cheers
If you apply tan on both sides first
tan( arctan(w/10^4) + arctan(w/10^5) +arctan(w/2*10^5) ) = 0
then simple use tan ( A + B +C ) = tanA*tanB*tanC/(1-(tanA*tanB)-(tanA*tanB*tanC)) formula
Immediately you see that w = 0 is a solution or you get a cubic at the bottom
w^3/(10^4*10^5*2*10^5)/(1-(w^2/10^4*10^5)-w^3/(10^4*10^5*2*10^5)
hope it helps
K
Reactions: baby_1
    baby_1
