grizedale
Advanced Member level 3
We need to stick 2cm by 3cm LED PCB's to an aluminium heatsink.
Do you know of a cheap , double sided sticky thermal pad that can be used for this?
Ideally we want it cheap and big enough to overlap the PCB at all sides so that we can be sure that the assembly staff have put it on properly , covering the whole of the interface of the pcb with the aluminium heatsink.
Glues tend to dry up on production lines, and thermal paste is awkward and can give rise to gaps if not fully pasted.
