purefen
Junior Member level 1
snsp corner
Dears:
Although a designer should know which corner case will degrade the performance of your designed circuit. But it is maybe the worst case which is out of 3-sgma ramge. If trying to overcome the worst case, the area and power of the circuit will raise. Will you do that? How many corner cases to sure the circuit being mass produce?
corner case:
rratio, cratio, i_ratio(internal current), ixp_ratio(external currnet), mos(tt,ff,fs,....)......
BR. purefen
Dears:
corner case:
BR. purefen
