[SOLVED] glcd interfacing with 8051
pratzz
Member level 5
Member level 5
i copied the code from engineersgarage.com and checked its functioning on proteus but on hardware implementation nothing is displayed just backlight seems to be glowing. i have used JHD12864e .Also 18th pin(Vee) is showing only +0.3 v. can anyone help me?
Don't Worry..
I will give you the code when i reach home...
I had used the JHD12864E and interfaced with PIC16F877a..
Till then u upload your code and Schematic Diagram
i actually used 8051,code seems to be rnning correctly on proteus.
I'm not sure whether my glcd is wrkin because i accidently gave pin no. 18 +5v for a short while.
I think your code is Okay....
But if it is possible for u to give the Circuit Diagram (Schematic) so that i can know how you connect your hardware...
As I am also using JHD12864E and its working for me....
Have you used a potentiometer between Vout Pin and VEE
Measure the Voltage on Vee pin.. i think it must be negative..
Check that and report back...
Tutorial on Graphical LCD can be found here
https://sites.google.com/site/coolembeddedlaboratory/home/pic18f4550/tutorial-list/graphical-lcd
Reactions: pratzz
    pratzz
schematic is exactly like that given in the link below.
yes i have connected the potientiometer but value at 18th pin is comin out to be +.3v.
my glcd was damaged.thnak u for helping me
