8051 out put pin frequency
getavinks@gmail.com
hello, i am using atmel 8051 with 11.0592 mhz crystal.
what will be the frequency when i make a pin high- low;
P1.0 = 1 ;
p1.0 = 0 ;
what will the frequency of p1.0 pin?
P1.0 = 1 ;
p1.0 = 0 ;
If you used 12MHz crystal the max frequency would be around 500kHz, with 11MHz it will be roughly 11/12 of that estimation ..
:wink:
IanP
Reactions: DrWhoF
    DrWhoF
:wink:
IanP
Thanks for your response.
How to calculate this frequency?
The original 8051 core runs at 12 clock cycles per machine cycle, with most instructions executing in one or two machine cycles.
So, one machine cycle takes 1 micro-sec if the 8051 is operating from a 12 MHz clock.
SET and CLR istructions are executed in one machine cycle.
1us+1us=2us ====> f=500kHz
:wink:
IanP
Reactions: DrWhoF
    DrWhoF
Execution time
The time needed to execute any particular instruction is determined by the formula
T is equal to C times 12 divides F
C is the number of cycles to execute the program
F is the frequency of the crystal
Reactions: DrWhoF
    DrWhoF
see 8051 has a DIVIDE by 12 circuit built inside. So first of all divid ur clk freq by 12 and then inverse gives execution time for each cycle.
12MHz/12 = 1MHz
Execution time = 1/1MHz = 1uS
so it will take 1uS for setting bit and then 1uS for reset bit
Hence 2uS
Hence frq = 1/2uS = 500kHz
HOPE IT HELPED !!!
Thanks it was help full
12MHz/12 = 1MHz
Hence 2uS
HOPE IT HELPED !!!
