zhipeng
In Encounter RTL Complier, is it possible to specify the tool to use UVT (Ultra-high Threshold Voltage) standard cell library for module A and RVT standard cell libray for all other modules?
Currently, I am using optLeakagePower in postroute stage of Place&Route. However, it seems that a significant portion of cells in module A not being replaced by UVT cells. So I need a way to start module A with only UVT cells, start from the synthesis stage. Thanks!
