Interfacing DHT11 with PIC
engshahrul
Banned
Full Member level 6
Malaysia
Hi, I'm trying interfacing DHT11 with PIC. I'm using Hi-Tech compiler.
From information all over datasheet and internet, after sending start signal, DHT11 will reply 5 byte data. The last one is check sum.
void dht11_start(void)
DataDir=0; // set pin as output
Data=0; // give low
__delay_ms(20);
Data=1;  //give high
__delay_us(30);
DataDir=1;  //set pin as input
while(Data==0) continue;
while(Data==1) continue;
char dht11_byte(void)
{int i;
char value=0;
for(i=0;i<8;i++){
	__delay_us(40);
	if(Data==1){
		value=value|(1<<(7-i));
		while(Data==1) continue;}
return value;
This is my DHT11 start signal and DHT11 read byte. I give start signal and read 5 byte. Another 1, I calculate the sum of 5 byte.
sum=temp[0]+temp[1]+temp[2]+temp[3]+temp[4];
sum=sum&0xFF;
But, the value sum not equal to the fifth byte read from DHT11. Anyone know how the above function?
any one help ,,, i need dht 11 c code for 89c51,,, with example ,,,,, and protius simulation this related dht.,. sht., like
---------- Post added at 08:49 ---------- Previous post was at 08:36 ----------
any one help ,,, i used ARM 9 friendly ARM mini 2440 .. .. linex how to conect internet ? please tell me step by step,,,,
i need protius simulation for dht 11 or sht 11 with 89c51... how to simulate ...??? then windows 7 sum time not fully instal protious ?? with version better for windows 7?????
