darksir
Junior Member level 1
Hi boys,
I need Liion backup for my GSM module apllication.
I have 12V supply, which is regulated to 4V. I found MCP73871 for Liion charging.
When I remake circuit and use this IC as power IC, with Liion backup, will be power supply enough for GSM module when I use this without Liion? Liion will be used optionally and I need one circuit for backup and nobackup circuits...
Thank you, Petr
Thank you, Petr
