thebadtall
Full Member level 6
Hello, ive been working on a 12v battery preamp 12au7 tube project, wich ended quite good.
Now I have found a new project to work on, wich needs 300v dc to feed the 12au7 plate.
I dont have the transformer, but I thought I could use a fluorescence tube transformer wich is 430v AC.
The problem here is that I dont know how to reduce the voltage to 300v. Can I use zenner or they will blow ?
Any suggestions please ?Thank you.
