ronins9720
Is it possible to transmit an end result generated by microprocessor through FM and vice-versa i.e can we also process the information received through FM on microprocessor? If possible please explain.
If interfacing is possible is mainly depending on logic levels, baud rate and if any serial parallel conversion is needed.Can we do the interface of barcode reader or RFID directly to data line of HT12E?
HT12E will not do anything else then distribute digital data.I mean can we perform different operations on data with the help of HT12E
