Why use bandgap reference voltage 1.024V???
diarmuid
Full Member level 2
Full Member level 2
Dublin, Ireland
Hello!
I have seen bandgap voltages of 1.024V being used by ADC's, where the other analog blocks make do with 1.2V.
Why does an ADC need such a reference voltage? Its something to do with 2^10 I presume, but not being an
ADC guru, I cant say what!
Thanks in advance,
Diarmuid
Hi diarmuid!
So, why 1.024V, it's for 1LSB => good for standardization of ADC. ;-)
And normally, this is reference voltage, i think it should not be called bandgap ref voltage, because the typical bandgap voltage is between 1.2 - 1.3 V, it is based on the theoretical value for silicon is 1.22eV at 0K.
Reactions: butchi
    butchi
