How to find the RTD PT100 resistance and temperature?
Full Member level 4
Hello!
With the circuit mentioned here I am getting a value of 2.82V @ 850 degree C. Can somebody tell me how to find the RTD PT100 resistance and temperature from Vo?
What is the equation for rtd resistance and temperature? I don't want to use look up tables.
Re: Help with RTD PT100 Circuit
It is about +4 ohms difference per degree C, with zero degrees C being 1000 ohms. So, 1 degree C would be 4 ohms.
However, most manufacturers have their own tables (since there is a difference slightly between different manufacturers).
So, for ultimate accuracy, lookup tables need to be used.
EDIT: sorry, that was for PT1000 - I need glasses clearly!
For PT100, read as 0.4 ohms and 100 ohms respectively.
I know that RTD resistance increase by 0.385 Ohms / degree C. What I want to know in this
circuit i, how to get rtd temperature and resistance from o/p voltage Vo. I'm getting 2.82V @ 850 degree C and 0.72V @ 0 degree C. the function is not linear.
It sounds about right.. not very familiar with this cct, but looks like an instrumentation amp set to a gain of 6.24??, and a constant current source of 1mA.
So, at 0 degrees, you'd get about (100ohms*0.001A)*6.24 = 0.624V and you're getting 0.72V
At 850 degrees you'd get ((0.4ohms*850degrees)+100ohms)*0.001A*6.24 = 2.7456V and you're getting 2.82V
Your values are a bit higher, maybe component tolerances mean the gain isn't quite 6.24 or something.. maybe it's an offset. What op-amps are you using? Are your results real or a simulation?
Have a look at Wikipedia for some background: https://en.wikipedia.org/wiki/Resistance_thermometer
As you can see, there is a simple formula that gives resistance as a function of temperature. Unfortunately they normally work in a limited range of temperature, and if you need to measure 850°C (or did you mean 85?) you are well beyond that range.
For a more physical description of PT100, you may have a look to the Italian Wikipedia (https://it.wikipedia.org/wiki/Termoresistenza) with an online service like google translate or bing translator.
Hope this helps.
The gain is 7.24 (1+ 20/3.205), not 6.24. The output voltages assumed by the original poster are exactly corresponding to nominal Pt100 resistance values. Resistance at 850 °C is specified as 390.481 ohm.
According to the circuit function, that has been basically analyzed correctly by sky_123, Rpt100 = Vo/7.24*1000. Output voltage to resistance is of course a linear function. Resistance to temperature is not exactly linear according to the Pt100 characteristic, but a assuming a linear relation may be sufficient for many cases, particularly in a smaller temperature range. What you most likely mean is that the linear function has a constant term b, Rpt100 = a*t + b. You can easily draw a straight line connecting the 0 an 850 °C points, it will involve about 30 degree deviation in the middle of the range. For an exact measurement, you should refer to a polynomial or a table.
A precise table calculation method has been suggested in an Analog Devices application note.
https://www.analog.com/static/imported-files/application_notes/AN709_0.pdf
https://www.analog.com/static/imported-files/application_notes/AN-709_files.zip
No, with resistance is taken as 0.389 Ohms / degree C. I'm simulating in proteus. I've plotted the graph for every 50 degree C. It is not linear. I want to find the value of temperature from Vo.
---------- Post added at 07:10 ---------- Previous post was at 06:56 ----------
In Rpt100 = a*t + b What is the value of a, b, and t. Without knowing t, I cannot calculate r, and without knowing r, I cannot calculate t. What is the polynomial equation for calculating rtd temperature and resistance.
I got this equation Rt = Ro [1 + At + Bt^2] for 0-850 degree C range. But I don't know t to calculate Rt.
---------- Post added at 07:18 ---------- Previous post was at 07:10 ----------
I am using LMP2011 MF and V+ = 5V
Sorry, your post doesn't make sense. With a the assumption of a linear Pt100 t.c., the output will be linear. Don't know if it's a problem of Proteus or your mathematics.
There should be A and B numbers given together with this equation. What's your problem in calculation then? Did you try a pocket calculator?
OK. I finished the project. I wanted to get the value of rtd pt100's resistance and rtd pt100's temperature from Vo of the Instrumentation amplifier.
  • pt 100.rar
Did you look into the AD application note?
Dp you mean PIC mcu datasheets ADC section?
I meant the application note linked in post #6.
I've checked those documents.
In this https://www.analog.com/static/imported-files/application_notes/AN709_0.pdf document there is an equation for T. You can check it for yourself. It is giving wrong values
In RTD Table for 500 Degree C, resistance = 280.98. So, you can put r = 280.98 and check fro yourself what the value comes for T. Ro = 100.
Please check it and tell me.
---------- Post added at 20:06 ---------- Previous post was at 20:02 ----------
In RTD Table for 500 Degree C, resistance = r = 280.98. So, you can put r = 280.98 and check for yourself what the value comes for T. Ro = 100.
Hello! I did like this. All variables are double type.
[syntax = c]
val1 = (100.00 - resistance)/100.00;
val2 = 4.0 * (-5.775e-7) * val1;
val3 = sqrt(15.27480889e-6 - val2);
val4 = -1.155e-6;
temperature = (-3.8093e-3 + val3) / val4;
[/syntax]
But it is giving wrong values.
I suggested the application note for it's table caculation, not the "direct method".
The direct calculation works perfectly, but there's a typo in your calculation
The most important disadvantage of the direct method is that it can't be applied to negative temperatures. And importng a sqrt() library may nbe inappropriate for small micros.
I fixed the typo. Here is my final project
How to do the negative temperature calculations?
---------- Post added at 15:52 ---------- Previous post was at 15:50 ----------
As said in the application note, inversion of the more complex polynomial defining the Pt100 standard resistance for negative temperatures isn't feasible.
For a temperature range down to -100 °C, the deviation isn't larger than 0.2 degree, so the calculation may still work for most technical Pt100 applications except cryo cooling. For lower negative temperatures or better accuracy, use a polynomial approximation or piecewise linear approximation (table interpolation), as explained in the application note´.
Can you put your code, please?
Hi internetuserk12,
Could you please upload your source code if it's not a problem for you.
Regards,
